Ir para o conteúdo principal
Canon EOS Rebel G Top Panel Replacement
O que você precisa
  1. Canon EOS Rebel G Top Panel Replacement, Front Panel: passo 1, imagem 1 %32
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Top Panel Replacement: passo 2, imagem 1 %32 Canon EOS Rebel G Top Panel Replacement: passo 2, imagem 2 %32
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Top Panel Replacement: passo 3, imagem 1 %32 Canon EOS Rebel G Top Panel Replacement: passo 3, imagem 2 %32 Canon EOS Rebel G Top Panel Replacement: passo 3, imagem 3 %32
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Top Panel Replacement, Top Panel: passo 4, imagem 1 %32
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Top Panel Replacement: passo 5, imagem 1 %32
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Top Panel Replacement: passo 6, imagem 1 %32
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Top Panel Replacement: passo 7, imagem 1 %32 Canon EOS Rebel G Top Panel Replacement: passo 7, imagem 2 %32 Canon EOS Rebel G Top Panel Replacement: passo 7, imagem 3 %32
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Zach
Membro desde: 04/04/12
43 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 14-9, Forte Spring 2012 Membro de Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
Membros da 5
Autoria de 36 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,907
