Ir para o conteúdo principal
Canon EOS Rebel G Lens Connector Replacement
O que você precisa
  1. Canon EOS Rebel G Lens Connector Replacement, Front Panel: passo 1, imagem 1 %32
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Lens Connector Replacement: passo 2, imagem 1 %32 Canon EOS Rebel G Lens Connector Replacement: passo 2, imagem 2 %32
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Lens Connector Replacement: passo 3, imagem 1 %32 Canon EOS Rebel G Lens Connector Replacement: passo 3, imagem 2 %32 Canon EOS Rebel G Lens Connector Replacement: passo 3, imagem 3 %32
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Lens Connector Replacement, Lens Connector: passo 4, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the 5 indicated screws
    • Five 6.2 mm Phillips screws
  5. Canon EOS Rebel G Lens Connector Replacement: passo 5, imagem 1 %32
    • Using your hands, remove the top black ring.
    • WARNING! The indicated piece is spring loaded. Prepare for it to eject when taking off top ring.
    • Spring located here.
  6. Canon EOS Rebel G Lens Connector Replacement: passo 6, imagem 1 %32 Canon EOS Rebel G Lens Connector Replacement: passo 6, imagem 2 %32
    • There are two silver metal rings.
    • Remove the top silver metal ring.
  7. Canon EOS Rebel G Lens Connector Replacement: passo 7, imagem 1 %32
    • Remove the bottom silver ring.
Conclusão
Zach
Membro desde: 04/04/12
43 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 14-9, Forte Spring 2012 Membro de Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
Membros da 5
Autoria de 36 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 1,763
