Ir para o conteúdo principal
Canon EOS Rebel G Grip Replacement
O que você precisa
  1. Canon EOS Rebel G Grip Replacement, Front Panel: passo 1, imagem 1 %32
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Grip Replacement: passo 2, imagem 1 %32 Canon EOS Rebel G Grip Replacement: passo 2, imagem 2 %32
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Grip Replacement: passo 3, imagem 1 %32 Canon EOS Rebel G Grip Replacement: passo 3, imagem 2 %32 Canon EOS Rebel G Grip Replacement: passo 3, imagem 3 %32
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Grip Replacement, Grip: passo 4, imagem 1 %32
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  5. Canon EOS Rebel G Grip Replacement: passo 5, imagem 1 %32
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  6. Canon EOS Rebel G Grip Replacement: passo 6, imagem 1 %32 Canon EOS Rebel G Grip Replacement: passo 6, imagem 2 %32
    • Use the flat end of a spudger to pop the grip off and remove grip.
Conclusão
Uma outra pessoa concluiu este guia.
Kyle Reis
Membro desde: 04/02/12
52 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-9, Forte Spring 2012 Membro de Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
Membros da 5
Autoria de 36 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,589
