Ir para o conteúdo principal
Canon EOS Rebel G Flash Replacement
O que você precisa
  1. Canon EOS Rebel G Flash Replacement, Front Panel: passo 1, imagem 1 %32
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Flash Replacement: passo 2, imagem 1 %32 Canon EOS Rebel G Flash Replacement: passo 2, imagem 2 %32
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Flash Replacement: passo 3, imagem 1 %32 Canon EOS Rebel G Flash Replacement: passo 3, imagem 2 %32 Canon EOS Rebel G Flash Replacement: passo 3, imagem 3 %32
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Flash Replacement, Flash: passo 4, imagem 1 %32 Canon EOS Rebel G Flash Replacement, Flash: passo 4, imagem 2 %32
    • Pop the flash up with your thumb
  5. Canon EOS Rebel G Flash Replacement: passo 5, imagem 1 %32
    • Unscrew the two screws on the front of the flash near the bulb cover.
  6. Canon EOS Rebel G Flash Replacement: passo 6, imagem 1 %32 Canon EOS Rebel G Flash Replacement: passo 6, imagem 2 %32 Canon EOS Rebel G Flash Replacement: passo 6, imagem 3 %32
    • Close the flash.
    • Lift the flash cover off.
  7. Canon EOS Rebel G Flash Replacement: passo 7, imagem 1 %32 Canon EOS Rebel G Flash Replacement: passo 7, imagem 2 %32
    • Pull off yellow capacitor from flash wiring.
  8. Canon EOS Rebel G Flash Replacement: passo 8, imagem 1 %32
    • Remove white cocking with a razor blade, and then unsolder connection.
  9. Canon EOS Rebel G Flash Replacement: passo 9, imagem 1 %32 Canon EOS Rebel G Flash Replacement: passo 9, imagem 2 %32
    • Remove the flash cover to access the flash bulb.
    • After wires are unsoldered, slide flash bulb out from housing.
Conclusão
Uma outra pessoa concluiu este guia.
Zach
Membro desde: 04/04/12
43 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 14-9, Forte Spring 2012 Membro de Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
Membros da 5
Autoria de 36 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 2,436
