Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
Remove the battery from inside the battery housing and set the cover aside.
Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
Remove the 6.4mm screw from the inside of the flash bezel.
Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
Remove the 6.4mm screw on the top of the inside edge of the battery hole.
