Ir para o conteúdo principal
Canon EOS 70D EFS 18-135mm Lens Main Board Replacement
O que você precisa
  1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: passo 1, imagem 1 %32 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: passo 1, imagem 2 %32 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: passo 1, imagem 3 %32
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 2, imagem 1 %32 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 2, imagem 2 %32
    • Remove the four 5.5-mm Phillips #000 screws for the lens mount ring (silver ring).
    • Remove the two 4-mm Phillips #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 3, imagem 1 %32 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 3, imagem 2 %32
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 4, imagem 1 %32 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 4, imagem 2 %32
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 5, imagem 1 %32 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 5, imagem 2 %32 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: passo 5, imagem 3 %32
    • Remove the two 4-mm Phillips #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
Conclusão
Uma outra pessoa concluiu este guia.
Paul
Membro desde: 03/12/18
792 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Duração total: 2,362
