Ir para o conteúdo principal
Canon EOS 60D USB Replacement connector
O que você precisa
  1. Canon EOS 60D USB Replacement connector, Exchange of the connecter card: passo 1, imagem 1 %32
    • Also look at the pdf file or I have some photos that could not be deposited in this tutorial
    • Photograph of the broken plug, the central part is no longer centred and moves, hence the loss of USB connection with the computer
  2. Canon EOS 60D USB Replacement connector, View of the defect: passo 2, imagem 1 %32 Canon EOS 60D USB Replacement connector, View of the defect: passo 2, imagem 2 %32 Canon EOS 60D USB Replacement connector, View of the defect: passo 2, imagem 3 %32
    • Seen from the broken socket, the central part almost no longer holds and goes wrong
    • Photo of the item to be replaced (new card)
  3. Canon EOS 60D USB Replacement connector, Or buy the replacement card: passo 3, imagem 1 %32
    • After a long search, I was able to find the famous map on the Aliexpress website
  4. Canon EOS 60D USB Replacement connector, tools required: passo 4, imagem 1 %32
    • Screwdrivers #00
    • Phone disassembly kit
  5. Canon EOS 60D USB Replacement connector: passo 5, imagem 1 %32
  6. Canon EOS 60D USB Replacement connector, Location of the screws to be removed: passo 7, imagem 1 %32 Canon EOS 60D USB Replacement connector, Location of the screws to be removed: passo 7, imagem 2 %32
  7. Canon EOS 60D USB Replacement connector, Trick: passo 8, imagem 1 %32
    • Small tip, to avoid losing the screws I put a magnet so that the screws are "glued" to the screwdriver
  8. Canon EOS 60D USB Replacement connector, After the operations described in the video: passo 9, imagem 1 %32 Canon EOS 60D USB Replacement connector, After the operations described in the video: passo 9, imagem 2 %32 Canon EOS 60D USB Replacement connector, After the operations described in the video: passo 9, imagem 3 %32
    • Once this video has been dismantled, you must see this
    • We can move on to disassembly the card
  9. Canon EOS 60D USB Replacement connector, Unbuttoning connecters and removal of screws: passo 10, imagem 1 %32
    • There are 5 screws left to loosen and 6 connecters to unbutton
    • Start removing the 2 connecters in photo 1 with a tweezer, take on the side of the plug without pulling the wires
  10. Canon EOS 60D USB Replacement connector, Removal of connectors: passo 11, imagem 1 %32
    • Remove the two cables from these two connecters, as well as the screw on the right
  11. Canon EOS 60D USB Replacement connector, Removal of the screws: passo 12, imagem 1 %32
    • 3 screws to remove, one of which is hidden under the yellow tape
    • Remove the plastic cable holder
  12. Canon EOS 60D USB Replacement connector, Screw removal: passo 13, imagem 1 %32
    • Remove the last screw
  13. Canon EOS 60D USB Replacement connector, Ribbon connecter: passo 14, imagem 1 %32
    • Detach the tablecloth by pulling underneath with a flat screwdriver or with an unfolded paper clip in the hole provided for this purpose
  14. Canon EOS 60D USB Replacement connector, Clear the card: passo 15, imagem 1 %32
    • This is the most delicate part to gently clear the card by moving it without forcing it, until it finds its pivot point
    • Be careful, because at the moment there is still a connecter connected under the card. However, the cable is long enough to take it out without worry
    • At the curvature of the red thread, a small bent visible next to the screw hole is observed. It is probably he who makes it so difficult to remove the card.
    • There is a second one on the upper part of the card next to the screw that was under the yellow tape.
  15. Canon EOS 60D USB Replacement connector, Video connecter removal: passo 16, imagem 1 %32
    • The connecter undoes very easily by levering on each side of the golden connecter
    • The wide arrow indicates where to pin the soft tablecloth
  16. Canon EOS 60D USB Replacement connector, Card withdrawn: passo 17, imagem 1 %32
    • Exchange the deposited card
  17. Canon EOS 60D USB Replacement connector, Reassembly of the card: passo 18, imagem 1 %32
    • Put the golden connecter back on, a slight pressure is enough
  18. Canon EOS 60D USB Replacement connector, Identification of the card centring picot: passo 19, imagem 1 %32
    • We see where the plastic pin is located that holds the printed circuit board, next to the screw hole
    • Locate the same principle on the top of the map
  19. Canon EOS 60D USB Replacement connector, Rest from the map: passo 20, imagem 1 %32
    • Reinsert the tablecloth into its connecter, without forcing, the hole of the tablecloth must be in the plastic pin to be in place
  20. Canon EOS 60D USB Replacement connector, Installation of the cables: passo 21, imagem 1 %32
    • Be careful, the screw on the side comes to the arrowhead, the other hole must remain free for the screw of the plastic case (I was wrong)
    • Proceeding with the opposite of the video, everything went well.
    • Just when you put the rear facade back, the screen no longer folded down completely, don't panic, just unlock the three side screws of the card you just changed. The different plastic parts must join without leaving an apparent day.
    • Review the end of the video or this problem is well explained, it is thanks to it that I solved this little problem
  21. Canon EOS 60D USB Replacement connector: passo 23, imagem 1 %32
    • Use 3M spray mount glue to glue the rubber sheath on the case
    • Good luck and good photos
Conclusão
To reassemble your device, follow the instructions in reverse order.
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
vallet
Membro desde: 05/21/20
337 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 1,130
