Ir para o conteúdo principal
Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement
O que você precisa
  1. Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: passo 1, imagem 1 %32 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: passo 1, imagem 2 %32 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: passo 1, imagem 3 %32
    • Hold the camera in a top view position allowing for a clear display of the broken top cover.
    • Observe and identify all the pieces of the shattered cover.
  2. Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: passo 2, imagem 1 %32 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: passo 2, imagem 2 %32 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Slowly slide the tip of the tweezers under a piece of the broken cover and lift up to remove the broken piece.
    • Use the tweezers to remove another piece of the broken cover.
    • Repeat until all the pieces of the shattered cover are removed.
    • If you begin by removing a piece that is located at an edge of the broken cover, it would facilitate the removal of the rest of the pieces.
    • Use the tweezers carefully while removing the plastic pieces in order to avoid damaging the LCD screen beneath.
Conclusão
8 outras pessoas executaram este guia.
Nazmi Bargouthi
Membro desde: 08/26/15
630 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 16-6, Wollert Fall 2015 Membro de USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 3,719
