Ir para o conteúdo principal
Canon EOS 60D Rubber grips Replacement
O que você precisa
  1. Canon EOS 60D Rubber grips Replacement, Rubber grips: passo 1, imagem 1 %32
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
Conclusão
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
10 outras pessoas executaram este guia.
Eric D
Membro desde: 11/13/12
1.377 Reputação
Autoria de 5 guias
1Comentário do guia
Where can we get replacement grips?
Luke Lin - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 12,375
