Ir para o conteúdo principal
Canon EOS 60D Rear LCD screen protective plastic cover Replacement
O que você precisa
  1. Canon EOS 60D Rear LCD screen protective plastic cover Replacement, Rear LCD Screen Dissasembly: passo 1, imagem 1 %32
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 3, imagem 1 %32 Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 3, imagem 2 %32
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear LCD screen protective plastic cover Replacement, Rear LCD Screen: passo 5, imagem 1 %32 Canon EOS 60D Rear LCD screen protective plastic cover Replacement, Rear LCD Screen: passo 5, imagem 2 %32
    • Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
    • Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
  6. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 6, imagem 1 %32
    • Finally, remove the LCD screen by grabbing the clear plastic tab and lifting it carefully.
  7. Canon EOS 60D Rear LCD screen protective plastic cover Replacement, Rear LCD screen protective plastic cover: passo 7, imagem 1 %32
    • Slowly insert the tip of the Jimmy between the damaged plastic cover and the plastic frame, which holds it, to loosen the connection between them.
    • The Jimmy is sharp, so take special care when using it to avoid damaging the plastic frame or causing personal injury.
  8. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 8, imagem 1 %32 Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 8, imagem 2 %32
    • Carefully slide the Jimmy through all corners of the plastic frame until it is detached from the plastic cover.
  9. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 9, imagem 1 %32 Canon EOS 60D Rear LCD screen protective plastic cover Replacement: passo 9, imagem 2 %32
    • Using your hand, lift the detached plastic cover off the plastic frame.
    • To place a new plastic cover, simply stick it to the frame in the appropriate position.
Conclusão
Nazmi Bargouthi
Membro desde: 08/26/15
591 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 16-6, Wollert Fall 2015 Membro de USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
Membros da 3
Autoria de 14 guias
2 comentários
I followed all the steps and was able to dis- and reassamble everything in under 30min. When you reassamble make sure that in step 4 the metalplate of the housing is turned correctly and the connector is in the right position. Both could be turned 180° and mounted incorrectly. Other than that easy repair.
Thanks guys
Oliver Stietz - Responder
Hi there, can anyone send me some amazon link so I can order the correct glass? Thanks so far.
Claudio Dantas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 2,182
