Ir para o conteúdo principal
Canon EOS 60D Rear LCD Screen Removal
O que você precisa
  1. Canon EOS 60D Rear LCD Screen Removal, Rear LCD Screen Dissasembly: passo 1, imagem 1 %32
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Removal: passo 2, imagem 1 %32
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Removal: passo 3, imagem 1 %32 Canon EOS 60D Rear LCD Screen Removal: passo 3, imagem 2 %32
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Removal: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
Conclusão
Tyler Vaal
Membro desde: 08/30/15
695 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-6, Wollert Fall 2015 Membro de USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 1,344
