Ir para o conteúdo principal
Canon EOS 60D Rear Cover Removal
O que você precisa
  1. Canon EOS 60D Rear Cover Removal, Rear LCD Screen Dissasembly: passo 1, imagem 1 %32
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear Cover Removal: passo 2, imagem 1 %32
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear Cover Removal: passo 3, imagem 1 %32 Canon EOS 60D Rear Cover Removal: passo 3, imagem 2 %32
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear Cover Removal: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear Cover Removal, Removing Rear Cover: passo 5, imagem 1 %32 Canon EOS 60D Rear Cover Removal, Removing Rear Cover: passo 5, imagem 2 %32
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
  6. Canon EOS 60D Rear Cover Removal: passo 6, imagem 1 %32 Canon EOS 60D Rear Cover Removal: passo 6, imagem 2 %32
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
  7. Canon EOS 60D Rear Cover Removal: passo 7, imagem 1 %32
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
  8. Canon EOS 60D Rear Cover Removal: passo 8, imagem 1 %32 Canon EOS 60D Rear Cover Removal: passo 8, imagem 2 %32
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
  9. Canon EOS 60D Rear Cover Removal: passo 9, imagem 1 %32 Canon EOS 60D Rear Cover Removal: passo 9, imagem 2 %32
    • Using the plastic opening tool, carefully pry off the the side cover.
  10. Canon EOS 60D Rear Cover Removal: passo 10, imagem 1 %32
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
  11. Canon EOS 60D Rear Cover Removal: passo 11, imagem 1 %32
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
  12. Canon EOS 60D Rear Cover Removal: passo 12, imagem 1 %32
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler Vaal
Membro desde: 08/30/15
719 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-6, Wollert Fall 2015 Membro de USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 2,715
