Ir para o conteúdo principal
Canon EOS 60D: Replacing Eye piece and Battery door
  1. Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: passo 1, imagem 1 %32 Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: passo 1, imagem 2 %32
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Canon EOS 60D: Replacing Eye piece and Battery door: passo 2, imagem 1 %32 Canon EOS 60D: Replacing Eye piece and Battery door: passo 2, imagem 2 %32
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
Conclusão
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
4 outras pessoas executaram este guia.
Eric D
Membro desde: 11/13/12
1.284 Reputação
Autoria de 5 guias
Um comentário
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 5,925
