Ir para o conteúdo principal
Canon EOS 5D Mark II Clock Battery Replacement
O que você precisa
  1. Canon EOS 5D Mark II Clock Battery Replacement, Clock Battery: passo 1, imagem 1 %32
    • Lift the rubber flap covering the input/output jacks.
  2. Canon EOS 5D Mark II Clock Battery Replacement: passo 2, imagem 1 %32
    • Using a Phillips #000, remove the single 3.4 mm screw.
    You have gone this far, replace the battery anyway.
    I used a little blue tack to keep the screw in place
    Ron B - Responder
  3. Canon EOS 5D Mark II Clock Battery Replacement: passo 3, imagem 1 %32
    • This step will permanently erase all user settings.
    • The memory battery can now be easily slid out of place.
    • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
    In this step you also should remove the black screws to the left end right of the memory battery screw. Otherwise you can not remove the in/out port plastic covering in step 6.
    Per Feet - Responder
Conclusão
15 outras pessoas executaram este guia.
Mike Seed
Membro desde: 09/22/14
2.956 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 1-6, Hickman Fall 2014 Membro de USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
Membros da 3
Autoria de 16 guias
3 comentários
This Battery for Clock only? or CMos and Personal setting to?
there has to be something to retain all these settings once the main battery pack goes dead and or is removed from the camera?
My User 1 Pictures styles wont Save? it'll save but once i turn off My Canon Eos 5D Mark II and then back on again, my Color /Contrast/Sharpness are all Dead Center/= back to Default AGAIN? :/
Any Help here?
THANK YOU,
Greg - Responder
I did not write the original post, but I believe once you remove this battery ALL custom changes and time will be gone. You will have to re-create them. Besides the rechargeable battery, the only one keeping track of some settings is this one.
CL
Carlos Lijeron - Responder
Will doing this reset the shutter count in the camera? Like when you go to an external program to see how many shutter actuations there have been over the lifetime of the camera, will that number be erased?
Tom Fewchuk - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 128
Duração total: 25,820
