Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to remove the back panel in order to access the LCD, buttons, speaker, and other parts.
O que você precisa
Peel back the rubber cover above the in/out ports to reveal two screw heads.
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
The back panel is now free from the rest of the device.
14 outras pessoas executaram este guia.
2 comentários
I had a loose back panel on my EOS 5d and your pictures and instructions gave me the courage to peel back the rubber and tighten screw (was out of its hole) and viola. No more squeak. Thanks so much for your pictorial. Best, John M
