Introdução
An Error 99 is an non specific error which means that camera doesn't know or have a code for the problem. In my case the shutter assembly needed replacing. This was a fairly involved process for a beginner such as myself.
This is not a comprehensive guide but should be used in conjunction with the Canon Service Manual and youtube videos. I hope that some of the pictures I took along the way might help you identify or remember how each step works.
Peças
Não são necessárias peças.
  1. Get the Canon 40D Service Repair Manual
    • Get the Canon 40D Service Repair Manual
    • Have a clean and organized workspace. I labelled plastic trays by step number and put all items for each step in a separate tray.
    • Watch a couple Youtube videos on this process
  2. Peel off rubber grips Peel off rubber grips
    • Peel off rubber grips
  3. take off front piece
    • take off front piece
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. take off rear connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
    • take off rear
    • connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
  6. Take off top cover Take off top cover Take off top cover
    • Take off top cover
  7. take off bottom plate disconnect and remove bottom board disconnect and remove bottom board
    • take off bottom plate
    • disconnect and remove bottom board
  8. remove CMOS assembly
    • remove CMOS assembly
  9. remove metal back
    • remove metal back
    • remove and replace shutter assembly, transfering components that aren't on the new one
Conclusão
5 outras pessoas concluíram este guia.
how do you replace the bridge (male portion on camera) other than putting the card in a card reader
wareibevictoriap - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 61
Todo: 4,358
