Ir para o conteúdo principal
Canon EOS 40D Flash Hot Shoe Replacement
O que você precisa
  1. Canon EOS 40D Flash Hot Shoe Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Flash Hot Shoe Replacement: passo 2, imagem 1 %32
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Flash Hot Shoe Replacement: passo 3, imagem 1 %32
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: passo 4, imagem 1 %32 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: passo 4, imagem 2 %32 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: passo 4, imagem 3 %32
    • Use a metal spudger or opening tool to gently lift the hotshoe plate and slide it off.
  5. Canon EOS 40D Flash Hot Shoe Replacement: passo 5, imagem 1 %32 Canon EOS 40D Flash Hot Shoe Replacement: passo 5, imagem 2 %32 Canon EOS 40D Flash Hot Shoe Replacement: passo 5, imagem 3 %32
    • Remove the four 4.0 mm Phillips #000 screws securing the flash shoe to the camera.
    • Remove the flash shoe.
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 12-3, Blackwell Fall 2015 Membro de USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Membros
Autoria de 16 guias
Um comentário
This is the best down to earth instructions i have ever had. No messing about even tells what screws and how to open the battery cover
Albert
albert irving - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 67
Ao todo: 4,808
