Ir para o conteúdo principal
Canon EOS 40D Battery Door Replacement
O que você precisa
  1. Canon EOS 40D Battery Door Replacement, Battery Door: passo 1, imagem 1 %32
    • After removing the battery, place your index finger between the inner section of the battery door and the battery compartment as shown in the photo.
    • Then place your thumb slightly above the battery door hinge.
  2. Canon EOS 40D Battery Door Replacement: passo 2, imagem 1 %32 Canon EOS 40D Battery Door Replacement: passo 2, imagem 2 %32
    • With your thumb, gently press down on the battery door and rotate the battery door clockwise. The upper hinge will pop out and then the lower hinge will pop out.
Conclusão
Doug Kruse
Membro desde: 09/03/15
745 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 12-3, Blackwell Fall 2015 Membro de USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
Membros da 4
Autoria de 16 guias
105 comentários
fhdfhdfhdfhdgfhfghfghffgjgfjfgfhdffhdfhdfhdfhdgfhfghfghffgjgfjfgfhdf
cyberov50 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 33
Duração total: 2,114
