Pular para o conteúdo principal
Introdução
Taking off the top of the camera allows repair access to the eye piece and command dial.
Peças
Nenhum componente especificado.
  1. Open up the battery door. Open up the battery door. Open up the battery door.
    • Open up the battery door.
  2. Remove the batteries from the camera by sliding them out into your palm. Remove the batteries from the camera by sliding them out into your palm.
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Release the side latch to open the back panel. Release the side latch to open the back panel.
    • Release the side latch to open the back panel.
  4. Remove the two black 4.5mm screws above and below the latch. Remove the two black 4.5mm screws above and below the latch.
    • Remove the two black 4.5mm screws above and below the latch.
  5. Using your finger, carefully pry open the side panel from the top of camera. Pull panel downwards to remove.
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Remove the two silver 6mm Phillips #1 screws. Remove the two silver 6mm Phillips #1 screws.
    • Remove the two silver 6mm Phillips #1 screws.
  7. Flip camera over to the bottom. Remove the one 5mm Phillips #1 silver screw.
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  9. Remove the front panel by pulling away from the side with the lever. Remove the front panel by pulling away from the side with the lever.
    • Remove the front panel by pulling away from the side with the lever.
  10. Remove three black 7.3mm Phillips #1 screws located on the corners of the camera. Remove five black 4.8mm Phillips #1 screws.
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  11. Simply remove the bottom panel by prying it off with your finger. When removing the panel, be sure the bottom of the camera is facing upright.  There are loose gears that may fall out. Be wary of a loose piece of foam attached to the bottom panel.
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  12. Remove the remote control socket cover. Remove the remote control socket cover. Remove the remote control socket cover.
    • Remove the remote control socket cover.
  13. Remove two black 4.5mm Phillips #1 screws. Remove two black 4.5mm Phillips #1 screws.
    • Remove two black 4.5mm Phillips #1 screws.
  14. Remove two black 4.8mm Phillips #1 screws on the front of the camera. Remove two black 4.8mm Phillips #1 screws on the front of the camera.
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  15. Pry open the side grip using a spudger. Pry open the side grip using a spudger.
    • Pry open the side grip using a spudger.
  16. With your hands, remove the rubber grip from the eye piece. With your hands, remove the rubber grip from the eye piece.
    • With your hands, remove the rubber grip from the eye piece.
  17. Remove the eyecup from the eyepiece by pushing the eyecup up.
    • Remove the eyecup from the eyepiece by pushing the eyecup up.
  18. Remove two silver 5.0mm Phillips #1 screws. Remove two silver 5.0mm Phillips #1 screws.
    • Remove two silver 5.0mm Phillips #1 screws.
  19. Remove the silver 5.5mm Phillips #1 screw.
    • Remove the silver 5.5mm Phillips #1 screw.
  20. Pry the top silver part of the camera off. Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
    • Pry the top silver part of the camera off.
    • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
Conclusão
Uma outra pessoa concluiu este guia.
Tammy Kong
Membro desde: 23-01-2014
664 reputação
6 Guias de autoria
Equipe
Cal Poly, Team 6-20, Maness Winter 2014 Membro de Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Membros
11 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Todo: 355
