Ir para o conteúdo principal
Canon EOS 300 Side Panel with Grip Replacement
O que você precisa
  1. Canon EOS 300 Side Panel with Grip Replacement, Batteries: passo 1, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement, Batteries: passo 1, imagem 2 %32 Canon EOS 300 Side Panel with Grip Replacement, Batteries: passo 1, imagem 3 %32
    • Open up the battery door.
  2. Canon EOS 300 Side Panel with Grip Replacement: passo 2, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 2, imagem 2 %32
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: passo 3, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: passo 3, imagem 2 %32
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Side Panel with Grip Replacement: passo 4, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 4, imagem 2 %32
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Side Panel with Grip Replacement: passo 5, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 5, imagem 2 %32
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Side Panel with Grip Replacement, Front Panel: passo 6, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement, Front Panel: passo 6, imagem 2 %32
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Side Panel with Grip Replacement: passo 7, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 7, imagem 2 %32
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Side Panel with Grip Replacement: passo 8, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 8, imagem 2 %32
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: passo 9, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: passo 9, imagem 2 %32
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Side Panel with Grip Replacement: passo 10, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 10, imagem 2 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 10, imagem 3 %32
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: passo 11, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: passo 11, imagem 2 %32 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: passo 11, imagem 3 %32
    • Remove the remote control socket cover.
  12. Canon EOS 300 Side Panel with Grip Replacement: passo 12, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 12, imagem 2 %32
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Side Panel with Grip Replacement: passo 13, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 13, imagem 2 %32
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Side Panel with Grip Replacement: passo 14, imagem 1 %32 Canon EOS 300 Side Panel with Grip Replacement: passo 14, imagem 2 %32
    • Pry open the side grip using a spudger.
Conclusão
Jordan Tang
Membro desde: 01/24/14
590 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-20, Maness Winter 2014 Membro de Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
Membros da 4
Autoria de 32 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 932
