Ir para o conteúdo principal
Canon EOS 30 Lens Mount Rings
O que você precisa
  1. Canon EOS 30 Lens Mount Rings, Front Panel: passo 1, imagem 1 %32
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Lens Mount Rings: passo 2, imagem 1 %32
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Lens Mount Rings: passo 3, imagem 1 %32
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Lens Mount Rings: passo 4, imagem 1 %32
    • Remove the front panel by lifting it away from the camera's body.
    I need a video tutorial
    Abdullah dicky S - Responder
  5. Canon EOS 30 Lens Mount Rings, Lens Mount Rings: passo 5, imagem 1 %32
    • Remove four 7.1 mm silver screws from lens mount ring.
  6. Canon EOS 30 Lens Mount Rings: passo 6, imagem 1 %32
    • Remove outer mount ring.
    • The silver button may detach.
  7. Canon EOS 30 Lens Mount Rings: passo 7, imagem 1 %32
    • Remove thin gold ring.
    • Correct orientation is pictured.
  8. Canon EOS 30 Lens Mount Rings: passo 8, imagem 1 %32
    • Remove thin silver ring.
Conclusão
Uma outra pessoa concluiu este guia.
Antonia
Membro desde: 04/17/11
124 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-8, Regan Spring 2011 Membro de Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
Membros da 5
Autoria de 22 guias
Um comentário
Very handy. One addition though - the silver button lever is on the wrong side - it is not facing the mirror box but the plastic lens release button. Plus, you are missing the fact that there is a spring underneatch the silver leaver which keeps the mount pin coming back up.
Patryk Granatowicz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 5,471
