Introdução
An image sensor is a key component in a camera's function. The imaging sensor senses and converys information that creates an image. It converts the variable flux of light waves into the signals that carry this information. The main issue that can occur with an imaging sensor is dust build up. This guide provides step by step instructions to replace your imaging sensor in your Canon ELPH Z3.
O que você precisa
Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
Pull apart the front and back coverings of the camera.
Remove the back covering completely to gain access of the rear screen.
Pull away back screen base to reveal the image sensor.
Remove image sensor using a set of pliers.
