Ir para o conteúdo principal
Canon ELPH Z3 Camera Image Sensor Replacement
O que você precisa
  1. Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: passo 1, imagem 1 %32 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: passo 1, imagem 2 %32 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: passo 1, imagem 3 %32
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Image Sensor Replacement: passo 2, imagem 1 %32 Canon ELPH Z3 Camera Image Sensor Replacement: passo 2, imagem 2 %32 Canon ELPH Z3 Camera Image Sensor Replacement: passo 2, imagem 3 %32
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Image Sensor Replacement: passo 3, imagem 1 %32 Canon ELPH Z3 Camera Image Sensor Replacement: passo 3, imagem 2 %32
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Image Sensor Replacement: passo 4, imagem 1 %32 Canon ELPH Z3 Camera Image Sensor Replacement: passo 4, imagem 2 %32 Canon ELPH Z3 Camera Image Sensor Replacement: passo 4, imagem 3 %32
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: passo 5, imagem 1 %32 Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: passo 5, imagem 2 %32
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Image Sensor Replacement: passo 6, imagem 1 %32 Canon ELPH Z3 Camera Image Sensor Replacement: passo 6, imagem 2 %32 Canon ELPH Z3 Camera Image Sensor Replacement: passo 6, imagem 3 %32
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Image Sensor Replacement: passo 7, imagem 1 %32 Canon ELPH Z3 Camera Image Sensor Replacement: passo 7, imagem 2 %32
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
  8. Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: passo 8, imagem 1 %32 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: passo 8, imagem 2 %32 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: passo 8, imagem 3 %32
    • Pull away back screen base to reveal the image sensor.
    • Remove image sensor using a set of pliers.
Conclusão
Katy Skillings
Membro desde: 10/21/16
1 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-7, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 267
