Ir para o conteúdo principal
Canon ELPH Z3 Camera Film Chamber Replacement
O que você precisa
  1. Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: passo 1, imagem 1 %32 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: passo 1, imagem 2 %32 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: passo 1, imagem 3 %32
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Film Chamber Replacement: passo 2, imagem 1 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 2, imagem 2 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 2, imagem 3 %32
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Film Chamber Replacement: passo 3, imagem 1 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 3, imagem 2 %32
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Film Chamber Replacement: passo 4, imagem 1 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 4, imagem 2 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 4, imagem 3 %32
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Film Chamber Replacement, Film: passo 5, imagem 1 %32 Canon ELPH Z3 Camera Film Chamber Replacement, Film: passo 5, imagem 2 %32
    • Separate the front and back coverings of the camera completely.
    • Remove both coverings from the body of the camera.
    • Flip the camera upside down and focus on the bottom right portion.
  6. Canon ELPH Z3 Camera Film Chamber Replacement: passo 6, imagem 1 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 6, imagem 2 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 6, imagem 3 %32
    • Unscrew the 4.1mm screw using a PH000 screwdriver.
    • Swivel the now loose metal portion to the right.
    • This action will open the film chamber and thus exposing the film.
  7. Canon ELPH Z3 Camera Film Chamber Replacement: passo 7, imagem 1 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 7, imagem 2 %32 Canon ELPH Z3 Camera Film Chamber Replacement: passo 7, imagem 3 %32
    • Press gently on the film using your finger to slightly eject the film.
    • Pull the film from the chamber.
Conclusão
Nathan Barros
Membro desde: 10/18/16
1 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-7, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 922
