Ir para o conteúdo principal
Canon ELPH Z3 Camera Battery Replacement
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: passo 1, imagem 1 %32 Canon ELPH Z3 Camera Battery  Replacement, Battery: passo 1, imagem 2 %32 Canon ELPH Z3 Camera Battery  Replacement, Battery: passo 1, imagem 3 %32
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: passo 2, imagem 1 %32 Canon ELPH Z3 Camera Battery  Replacement: passo 2, imagem 2 %32
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
Conclusão
Nathan Barros
Membro desde: 10/18/16
1 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-7, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Duração total: 714
