Introdução
If you're having issues as a result of a dirty or faulty white document mat, this is where you will want to begin.
To remove the white document mat, you must:
- Carefully rip out the foam that's glued onto the cover.
- Glue in the replacement document mat.
O que você precisa
Quase terminado!
To reassemble your device, ensure that the white document mat is firmly glued on.
Conclusão
Uma outra pessoa concluiu este guia.
