Ir para o conteúdo principal
Canon AE-1 SLR Lens Mount Replacement
O que você precisa
  1. Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: passo 1, imagem 1 %32 Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: passo 1, imagem 2 %32
    • Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver.
    • The first set of screws is located on the front and bottom of the lens casing.
  2. Canon AE-1 SLR Lens Mount Replacement: passo 2, imagem 1 %32 Canon AE-1 SLR Lens Mount Replacement: passo 2, imagem 2 %32
    • Remove the remaining two screws from the right and left sides of the lens outer casing using a Phillips #00 screwdriver.
  3. Canon AE-1 SLR Lens Mount Replacement: passo 3, imagem 1 %32
    • Remove the lens casing by pulling it away from the body of the camera.
  4. Canon AE-1 SLR Lens Mount Replacement: passo 4, imagem 1 %32
    • Remove the four #00 screws from the SLR lens mount using a Phillips #00 screwdriver.
  5. Canon AE-1 SLR Lens Mount Replacement: passo 5, imagem 1 %32 Canon AE-1 SLR Lens Mount Replacement: passo 5, imagem 2 %32 Canon AE-1 SLR Lens Mount Replacement: passo 5, imagem 3 %32
    • Pull the SLR lens mount away from the body of the camera.
    • Be aware that a pin will fall out when the SLR lens mount is removed.
Conclusão
6 outras pessoas executaram este guia.
Joe Blumberg
Membro desde: 10/04/11
213 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team 5-1, Zhou Fall 2011 Membro de UW Stout, Team 5-1, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G1
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 12,280
