Ir para o conteúdo principal
Canon AE-1 Light Filter Foam Replacement
O que você precisa
  1. Canon AE-1 Light Filter Foam Replacement, Light Filter Foam: passo 1, imagem 1 %32
    • Open the film compartment by pulling on the release pin.
    • Use a 3mm slot screw driver to scrape old light filter foam cleanly off.
    • Then use Isopropyl Alcohol to assist in removing the old light filter foam.
  2. Canon AE-1 Light Filter Foam Replacement: passo 2, imagem 1 %32
    • Placing light filter foam improperly could result in light exposure on film.
    • Cut the new light filter foam to size so it can fit in the slot.
    • Place the sticky side of the new strip of light filter foam over old foams location.
Conclusão
To reassemble your device, follow these instructions.
Brad
Membro desde: 10/04/11
47 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team 5-1, Zhou Fall 2011 Membro de UW Stout, Team 5-1, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 50
Duração total: 13,232
