Ir para o conteúdo principal
Canon 7210 Fan Replacement
O que você precisa
  1. Canon 7210 Fan Replacement, Exterior Shell: passo 1, imagem 1 %32 Canon 7210 Fan Replacement, Exterior Shell: passo 1, imagem 2 %32
    • Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
  2. Canon 7210 Fan Replacement: passo 2, imagem 1 %32 Canon 7210 Fan Replacement: passo 2, imagem 2 %32 Canon 7210 Fan Replacement: passo 2, imagem 3 %32
    • Gently lift up on the shell with both hands, from the back to the front.
    • The shell will still be attached by a small cord in the front, so be careful not to tear it loose.
  3. Canon 7210 Fan Replacement, Fan: passo 3, imagem 1 %32
    • Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
  4. Canon 7210 Fan Replacement: passo 4, imagem 1 %32
    • Remove the fan by pulling up gently from the top.
    • Be careful to not pull too hard or quickly, since the fan is still attached to the projector with some other wires.
  5. Canon 7210 Fan Replacement: passo 5, imagem 1 %32
    • Remove the 7mm Phillips #0 screw that fastens the black ground wire connected to the fan and the projector.
  6. Canon 7210 Fan Replacement: passo 6, imagem 1 %32
    • Peel the sticker up on the back of the fan to expose the port where the red, white, and black wires are attached.
    • The wires will need to be cut with small wire cutters in order to completely remove the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 9-3, Lacy Fall 2016 Membro de USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 319
