Ir para o conteúdo principal
CanoScan LiDE 35 Square Port Removal
O que você precisa
  1. CanoScan LiDE 35 Square Port Removal, Scanner Glass: passo 1, imagem 1 %32 CanoScan LiDE 35 Square Port Removal, Scanner Glass: passo 1, imagem 2 %32 CanoScan LiDE 35 Square Port Removal, Scanner Glass: passo 1, imagem 3 %32
    • Slide plastic opening tool under the plastic.
    • Gently pry the plastic framing off the glass.
    • Repeat on the other side.
  2. CanoScan LiDE 35 Square Port Removal: passo 2, imagem 1 %32 CanoScan LiDE 35 Square Port Removal: passo 2, imagem 2 %32
    • Remove the front plastic frame.
  3. CanoScan LiDE 35 Square Port Removal: passo 3, imagem 1 %32 CanoScan LiDE 35 Square Port Removal: passo 3, imagem 2 %32 CanoScan LiDE 35 Square Port Removal: passo 3, imagem 3 %32
    • Wedge the plastic opening tool under the glass.
    • Pull up against glass.
    • Slide the glass forward.
    • Remove the glass.
  4. CanoScan LiDE 35 Square Port Removal, Square Port: passo 4, imagem 1 %32 CanoScan LiDE 35 Square Port Removal, Square Port: passo 4, imagem 2 %32 CanoScan LiDE 35 Square Port Removal, Square Port: passo 4, imagem 3 %32
    • Locate three screws on the grey shell.
    • Unscrew the three screws.
    • Separate the grey shell from case.
  5. CanoScan LiDE 35 Square Port Removal: passo 5, imagem 1 %32 CanoScan LiDE 35 Square Port Removal: passo 5, imagem 2 %32 CanoScan LiDE 35 Square Port Removal: passo 5, imagem 3 %32
    • Separate the grey shell from square port.
  6. CanoScan LiDE 35 Square Port Removal: passo 6, imagem 1 %32 CanoScan LiDE 35 Square Port Removal: passo 6, imagem 2 %32 CanoScan LiDE 35 Square Port Removal: passo 6, imagem 3 %32
    • Locate the ribbon cable on casing.
    • Remove the ribbon cable on casing.
  7. CanoScan LiDE 35 Square Port Removal: passo 7, imagem 1 %32
    • Once the ribbon cable is removed, locate the square port.
    • Remove the square port.
Conclusão
Shannon
Membro desde: 10/28/13
364 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 1-89, Diaz Fall 2013 Membro de Clemson, Team 1-89, Diaz Fall 2013
CLEM-DIAZ-F13S1G89
1 Membro
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 52
Ao todo: 1,241
