Ir para o conteúdo principal
Canary CAN100USBK Ethernet PCB Board Replacement
O que você precisa
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: passo 1, imagem 1 %32 Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: passo 1, imagem 2 %32
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Ethernet PCB Board Replacement: passo 2, imagem 1 %32
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Ethernet PCB Board Replacement: passo 3, imagem 1 %32 Canary CAN100USBK Ethernet PCB Board Replacement: passo 3, imagem 2 %32 Canary CAN100USBK Ethernet PCB Board Replacement: passo 3, imagem 3 %32
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Ethernet PCB Board Replacement: passo 4, imagem 1 %32 Canary CAN100USBK Ethernet PCB Board Replacement: passo 4, imagem 2 %32
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Ethernet PCB Board Replacement: passo 5, imagem 1 %32 Canary CAN100USBK Ethernet PCB Board Replacement: passo 5, imagem 2 %32
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: passo 6, imagem 1 %32
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Ethernet PCB Board Replacement: passo 7, imagem 1 %32 Canary CAN100USBK Ethernet PCB Board Replacement: passo 7, imagem 2 %32
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Ethernet PCB Board Replacement: passo 8, imagem 1 %32
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
Conclusão
Tommy Nguyen
Membro desde: 02/28/17
597 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G2, Nance Spring 2017 Membro de USF Tampa, Team S1-G2, Nance Spring 2017
USFT-NANCE-S17S1G2
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,078
