Pular para o conteúdo principal
  1. The check engine light is on
    • The check engine light is on
  2. Hooking up the scan tool to find what is wrong The scan code is: p1391 which is cam shaft sensor code .
    • Hooking up the scan tool to find what is wrong
    • The scan code is: p1391 which is cam shaft sensor code .
  3. unplug the senor wire and get a tiny ranch and take the two pots off
    • unplug the senor wire and get a tiny ranch and take the two pots off
  4. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Pull the sensor straight off
    • Pull the sensor straight off
  6. buy a new sensor
    • buy a new sensor
  7. Put the sensor in the same direction that was pointed it when you take it off
    • Put the sensor in the same direction that was pointed it when you take it off
  8. Tighten the two pots so it does not slip and plug back it
    • Tighten the two pots so it does not slip and plug back it
  9. Get the scan tools and reset it so the check engine light goes off Turn the key to on position Select erase code
    • Get the scan tools and reset it so the check engine light goes off
    • Turn the key to on position
    • Select erase code
    • Hit yes
  10. the check engine light is off
    • the check engine light is off
Conclusão
adel_hydey
Membro desde: 06-03-2018
361 reputação
2 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 21
