Ir para o conteúdo principal
Campbell Hausfeld FP204800 Pressure Gauge Replacement
O que você precisa
  1. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: passo 1, imagem 1 %32 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: passo 1, imagem 2 %32 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: passo 1, imagem 3 %32
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: passo 2, imagem 1 %32 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: passo 2, imagem 2 %32
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: passo 3, imagem 1 %32
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the On/Off Switch Wiring: passo 4, imagem 1 %32
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: passo 5, imagem 1 %32 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: passo 5, imagem 2 %32
    • Using a Smart Wrench, remove the old/broken pressure gauge or gauges.
Conclusão
Eric
Membro desde: 10/09/14
409 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 14-29, Maness Fall 2014 Membro de Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 974
