Introdução
The check valve replacement is straight forward. You will need to remove the shroud of the compressor. However, not much more disassembly is required for this replacement.
O que você precisa
Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
Gently pull the wire attached from the pressure switch to the on/off switch.
It should come off the pressure switch with ease.
Gently pull the wire connected from the on/off switch to the motor of the compressor.
Unscrew the exhaust tube from the check valve using a Smart Wrench.
Unscrew the check valve by twisting it counter-clockwise using a Smart Wrench.
Uma outra pessoa concluiu este guia.
2 comentários
I never thought that it will be that much easy. I was looking for this kind of guide and thanks to ifixit and author of this guide I have successfully did the check valve replacement. Thanks for sharing this.
1. How do you know if it’s the pressure switch that’s bad?
2. What do ya do when they say the parts are discontinued??
