Ir para o conteúdo principal
Cambridge SoundWorks OontZ Angle Plus Speakers Replacement
O que você precisa
  1. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Rubber Casing: passo 1, imagem 1 %32
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 2, imagem 1 %32
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 3, imagem 1 %32
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 4, imagem 1 %32
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speaker Grill: passo 5, imagem 1 %32
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 6, imagem 1 %32
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 7, imagem 1 %32
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 8, imagem 1 %32
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 9, imagem 1 %32
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 10, imagem 1 %32 Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 10, imagem 2 %32
    • Finally, bend the speaker cover upward and it will slide out.
  11. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speakers: passo 11, imagem 1 %32
    • With some force, push the motherboard straight in toward the center of the device.
  12. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 12, imagem 1 %32
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This makes the motherboard fit in the groove rather tight.
  13. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 13, imagem 1 %32
    • Unplug the speaker's connector from the motherboard.
  14. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 14, imagem 1 %32
    • Unscrew the eight screws holding the speakers in place.
  15. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 15, imagem 1 %32
    • Desolder the the wires connected to the back side of both speakers.
  16. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: passo 16, imagem 1 %32
    • Carefully push the speakers out one at a time.
Conclusão
David Rice
Membro desde: 02/10/16
161 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Nance Spring 2016 Membro de USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,917
