Ir para o conteúdo principal
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
O que você precisa
  1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: passo 1, imagem 1 %32 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: passo 1, imagem 2 %32
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: passo 2, imagem 1 %32
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 3, imagem 1 %32
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 4, imagem 1 %32
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 5, imagem 1 %32
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 6, imagem 1 %32
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 7, imagem 1 %32
    • With some force, push the motherboard straight in toward the center of the device.
  8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 8, imagem 1 %32
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 9, imagem 1 %32
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
  10. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: passo 10, imagem 1 %32
    • Unplug the wires that connect the speakers to the motherboard.
  11. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 11, imagem 1 %32
    • Unplug the thin white cable connected to the buttons.
  12. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 12, imagem 1 %32 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: passo 12, imagem 2 %32
    • Desolder the wires that connect the LED to the motherboard.
Conclusão
Equipe
USF Tampa, Team 1-1, Nance Spring 2016 Membro de USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,859
