Ir para o conteúdo principal
Cambridge Audio A3i Power Cord and Transformer Replacement
O que você precisa
  1. Cambridge Audio A3i Power Cord and Transformer Replacement, Case: passo 1, imagem 1 %32
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Power Cord and Transformer Replacement: passo 2, imagem 1 %32
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Power Cord and Transformer Replacement: passo 3, imagem 1 %32 Cambridge Audio A3i Power Cord and Transformer Replacement: passo 3, imagem 2 %32
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Power Cord and Transformer Replacement: passo 4, imagem 1 %32
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Power Cord and Transformer Replacement, Power Cord and Transformer: passo 5, imagem 1 %32
    • Carefully de-solder ends of power cord from circuit board.
    • Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
    • Finally, pull the power cord through the rear panel to completely remove it.
  6. Cambridge Audio A3i Power Cord and Transformer Replacement: passo 6, imagem 1 %32
    • To remove the transformer the motherboard must be removed. This is to gain access to the solder on the power cords. -See guide for removing motherboard.
    • Remove the 4 nuts holding down the transformer bracket using a 7mm nut driver or socket.
Conclusão
6 outras pessoas executaram este guia.
Colby
Membro desde: 04/15/10
356 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 28-36, Regan Spring 2010 Membro de Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 108
Ao todo: 7,608
