Ir para o conteúdo principal
Cambridge Audio A3i Motherboard Replacement
O que você precisa
  1. Cambridge Audio A3i Motherboard Replacement, Case: passo 1, imagem 1 %32
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Motherboard Replacement: passo 2, imagem 1 %32
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Motherboard Replacement: passo 3, imagem 1 %32 Cambridge Audio A3i Motherboard Replacement: passo 3, imagem 2 %32
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Motherboard Replacement: passo 4, imagem 1 %32
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
  6. Cambridge Audio A3i Motherboard Replacement: passo 6, imagem 1 %32
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
  7. Cambridge Audio A3i Motherboard Replacement: passo 7, imagem 1 %32 Cambridge Audio A3i Motherboard Replacement: passo 7, imagem 2 %32
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
Conclusão
Uma outra pessoa concluiu este guia.
Colby
Membro desde: 04/15/10
356 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 28-36, Regan Spring 2010 Membro de Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 31
Duração total: 6,696
