Ir para o conteúdo principal
Calculator is Stuck While Graphing
  1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: passo 1, imagem 1 %32
    • To cancel the graphing process, press the "ON" button.
  2. Calculator is Stuck While Graphing: passo 2, imagem 1 %32 Calculator is Stuck While Graphing: passo 2, imagem 2 %32 Calculator is Stuck While Graphing: passo 2, imagem 3 %32
    • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
  3. Calculator is Stuck While Graphing: passo 3, imagem 1 %32
    • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
    • The bar on the top right corner indicates the calculator is graphing.
  4. Calculator is Stuck While Graphing: passo 4, imagem 1 %32 Calculator is Stuck While Graphing: passo 4, imagem 2 %32
    • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
Conclusão
It is always a good idea to make sure your graph will display a good window.
John Baek
Membro desde: 09/27/12
31 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-52, Forte Fall 2012 Membro de Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 35
Duração total: 1,907
