Ir para o conteúdo principal
Cabinet Door Butt Hinge Replacement
O que você precisa
  1. Cabinet Door Butt Hinge Replacement, Cabinet Door Butt Hinge: passo 1, imagem 1 %32
    • Determine where the cabinet needs repair: on the top or bottom hinge.
  2. Cabinet Door Butt Hinge Replacement: passo 2, imagem 1 %32
    • Measure the hinge to make sure you have the correct size of your butt hinge.
    • Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
  3. Cabinet Door Butt Hinge Replacement: passo 3, imagem 1 %32
    • Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
    • Keep the screws nearby; you will need them later.
  4. Cabinet Door Butt Hinge Replacement: passo 4, imagem 1 %32
    • Align the cabinet door to stand straight with any surrounding cabinets.
  5. Cabinet Door Butt Hinge Replacement: passo 5, imagem 1 %32
    • Place the new hinge where the previous one was. Align the holes together.
  6. Cabinet Door Butt Hinge Replacement: passo 6, imagem 1 %32
    • Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
Conclusão
If the door closes parallel to any surrounding cabinets, your fix is complete!
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 54
Duração total: 248
