Ir para o conteúdo principal
Cabin air filter replacement for a SEAT Cordoba II (2002-2009)
O que você precisa
  1. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: passo 1, imagem 1 %32 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: passo 1, imagem 2 %32
    • The cabin air filter is located in the passenger side footwell
  2. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: passo 2, imagem 1 %32 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: passo 2, imagem 2 %32 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: passo 2, imagem 3 %32
    • Remove the cover by loosening the four screws that hold it in place, keeping track of where they go to replace them in the some holes.
    • Once that the screws are removed, the cover will come down.
  3. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: passo 3, imagem 1 %32 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: passo 3, imagem 2 %32 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: passo 3, imagem 3 %32
    • Now with more room to remove it, slide the two plastic tabs together.
    • When the two plastic tabs are in the middle pull the filter cover down.
  4. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: passo 4, imagem 1 %32 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: passo 4, imagem 2 %32
    • Remove the filter.
    • Once you remove the filter make sure to notice the direction of the air-flow arrows so that you install the new one in the same direction.
  5. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Re-assembly: passo 5, imagem 1 %32
    • To install the new filter follow the previous steps in reverse. If the filter and the plastic cover don't install fully, it is possible that it is installed backwards.
    • When re-installing the cover re-insert the tab and push upwards. Then reinstall the screws.
Linha de Chegada
8 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
es en
100%
WhoDat? está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Jonatan M
Membro desde: 03/17/18
756 Reputação
Autoria de 2 guias
1Comentário do guia
me agremio para conocer formas de reparar yo mismo y economisar el presupuesto mensual
oscar ibarra - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 61
Últimos 30 dias: 258
Ao todo: 13,246
