Ir para o conteúdo principal
CHUWI GemiBook XPro Screen Replacement
O que você precisa
  1. CHUWI GemiBook XPro Screen Replacement, Battery: passo 1, imagem 1 %32 CHUWI GemiBook XPro Screen Replacement, Battery: passo 1, imagem 2 %32
    • Peel off the black tape on the upper-right side of the motherboard.
  2. CHUWI GemiBook XPro Screen Replacement: passo 2, imagem 1 %32 CHUWI GemiBook XPro Screen Replacement: passo 2, imagem 2 %32
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  3. CHUWI GemiBook XPro Screen Replacement: passo 3, imagem 1 %32 CHUWI GemiBook XPro Screen Replacement: passo 3, imagem 2 %32 CHUWI GemiBook XPro Screen Replacement: passo 3, imagem 3 %32
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  4. CHUWI GemiBook XPro Screen Replacement: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  5. CHUWI GemiBook XPro Screen Replacement: passo 5, imagem 1 %32 CHUWI GemiBook XPro Screen Replacement: passo 5, imagem 2 %32 CHUWI GemiBook XPro Screen Replacement: passo 5, imagem 3 %32
    • Lift the battery up and out of the chassis.
  6. CHUWI GemiBook XPro Screen Replacement, Screen: passo 6, imagem 1 %32
    • Carefully open the device screen side down.
  7. CHUWI GemiBook XPro Screen Replacement: passo 7, imagem 1 %32 CHUWI GemiBook XPro Screen Replacement: passo 7, imagem 2 %32 CHUWI GemiBook XPro Screen Replacement: passo 7, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the four 4.3 mm screws on the left hinge, and the three 4.3 mm screws on the right hinge.
    • Use a Phillips #1 screwdriver to remove one 5.6 mm hinge screw on the lower-right side of the right hinge.
  8. CHUWI GemiBook XPro Screen Replacement: passo 8, imagem 1 %32 CHUWI GemiBook XPro Screen Replacement: passo 8, imagem 2 %32 CHUWI GemiBook XPro Screen Replacement: passo 8, imagem 3 %32
    • Peel back the black tape near the right hinge.
  9. CHUWI GemiBook XPro Screen Replacement: passo 9, imagem 1 %32 CHUWI GemiBook XPro Screen Replacement: passo 9, imagem 2 %32
    • Disconnect the display ribbon cable.
  10. CHUWI GemiBook XPro Screen Replacement: passo 10, imagem 1 %32 CHUWI GemiBook XPro Screen Replacement: passo 10, imagem 2 %32
    • Lift the screen assembly off of the chassis.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 46
Ao todo: 118
