Ir para o conteúdo principal
CHI Spin N Curl Rotating Curler Motherboard Replacement
O que você precisa
  1. CHI Spin N Curl Rotating Curler Motherboard Replacement, Power Cord: passo 1, imagem 1 %32
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 2, imagem 1 %32
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 3, imagem 1 %32 CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 3, imagem 2 %32
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 4, imagem 1 %32 CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 4, imagem 2 %32
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 5, imagem 1 %32 CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 5, imagem 2 %32 CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 5, imagem 3 %32
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Motherboard Replacement, Power Cord: passo 6, imagem 1 %32
  7. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 7, imagem 1 %32
  8. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 8, imagem 1 %32 CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 8, imagem 2 %32
  9. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 9, imagem 1 %32 CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 9, imagem 2 %32
  10. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 10, imagem 1 %32 CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 10, imagem 2 %32 CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 10, imagem 3 %32
  11. CHI Spin N Curl Rotating Curler Motherboard Replacement, Motherboard: passo 11, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the screws holding the barrel in.
  12. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the screws using Phillips #00 screwdriver and take off the components.
    • Once all screws are removed, take out the barrel accessing the motherboard underneath.
  13. CHI Spin N Curl Rotating Curler Motherboard Replacement: passo 13, imagem 1 %32
    • Using metal spudger, lift and remove the motherboard and disconnect the top components.
Conclusão
Annalise White
Membro desde: 10/26/22
530 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Membro de UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 278
