Ir para o conteúdo principal
CHI Original Power Cord Replacement
O que você precisa
  1. CHI Original Power Cord Replacement, Hinge Spring: passo 1, imagem 1 %32 CHI Original Power Cord Replacement, Hinge Spring: passo 1, imagem 2 %32
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Power Cord Replacement: passo 2, imagem 1 %32
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Power Cord Replacement: passo 3, imagem 1 %32
    • Remove the hinge pin.
  4. CHI Original Power Cord Replacement: passo 4, imagem 1 %32
    • Separate the two halves of the CHI Original.
  5. CHI Original Power Cord Replacement: passo 5, imagem 1 %32 CHI Original Power Cord Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Power Cord Replacement, Power Cord: passo 6, imagem 1 %32 CHI Original Power Cord Replacement, Power Cord: passo 6, imagem 2 %32
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Power Cord Replacement: passo 7, imagem 1 %32
    • Gently pull upwards on the connection point and disconnect the power cord.
Conclusão
Eric Knigga
Membro desde: 08/23/17
224 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G2, Freund Fall 2017 Membro de IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
Membros da 4
Autoria de 3 guias
5 comentários
Do you know where to get a replacement power cord?
Taylor Bradford - Responder
How/where do you purchase the replacement cord?
fixitman - Responder
Where do you order an actual cord from??
Kelly Hickman - Responder
Where we can get Power Cord?
Nazim - Responder
Bonjour Nazim, j'ai trouvé le bon câble pour réparer le modèle GF1001EUN Farouk Systems USA sur le site web de pgservice :
Hi Nazim, I found the right cable to repair the GF1001EUN Farouk Systems USA model on the pgservice website :
https://pgservice.cc/fr/products/gammapi...
Sonny -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 46
Duração total: 6,981
