Ir para o conteúdo principal
CHI Original Circuit Board Replacement
O que você precisa
  1. CHI Original Circuit Board Replacement, Hinge Spring: passo 1, imagem 1 %32 CHI Original Circuit Board Replacement, Hinge Spring: passo 1, imagem 2 %32
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Circuit Board Replacement: passo 2, imagem 1 %32
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Circuit Board Replacement: passo 3, imagem 1 %32
    • Remove the hinge pin.
  4. CHI Original Circuit Board Replacement: passo 4, imagem 1 %32
    • Separate the two halves of the CHI Original.
  5. CHI Original Circuit Board Replacement: passo 5, imagem 1 %32 CHI Original Circuit Board Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Circuit Board Replacement, Power Cord: passo 6, imagem 1 %32 CHI Original Circuit Board Replacement, Power Cord: passo 6, imagem 2 %32
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Circuit Board Replacement: passo 7, imagem 1 %32
    • Gently pull upwards on the connection point and disconnect the power cord.
  8. CHI Original Circuit Board Replacement, Circuit Board: passo 8, imagem 1 %32 CHI Original Circuit Board Replacement, Circuit Board: passo 8, imagem 2 %32 CHI Original Circuit Board Replacement, Circuit Board: passo 8, imagem 3 %32
    • Remove the (2) .27" Phillips head screws on each half of the CHI Original.
  9. CHI Original Circuit Board Replacement: passo 9, imagem 1 %32 CHI Original Circuit Board Replacement: passo 9, imagem 2 %32 CHI Original Circuit Board Replacement: passo 9, imagem 3 %32
    • Remove the covers on both halves.
  10. CHI Original Circuit Board Replacement: passo 10, imagem 1 %32
    • Remove (2) .15" Phillips screws from the circuit board.
  11. CHI Original Circuit Board Replacement: passo 11, imagem 1 %32 CHI Original Circuit Board Replacement: passo 11, imagem 2 %32
    • Desolder all points of contact between the circuit board and wires on the ceramic heating elements.
Conclusão
Eric Knigga
Membro desde: 08/23/17
224 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G2, Freund Fall 2017 Membro de IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 27
Últimos 30 dias: 68
Duração total: 3,428
