Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the calculator over so the bottom is facing upwards.
Remove the screw from the battery hatch on the top-right corner using a 1.5 mm slotted screwdriver.
Remove the battery hatch.
Insert a spudger into the dent to the left of the battery until it hits the bottom of the panel board.
To create leverage, gently push the spudger towards the bottom of the battery (pushing your hand downwards and towards the back cover if necessary) to lift the battery out of its compartment.
Make sure the flat side of the battery is facing upwards.
To finish inserting the new battery into the battery compartment, gently press the bulged corner with your finger until it slides into place.
Flip the calculator on its back and press the 'ON' button to power it up.
A zero will appear on the bottom right corner of the LED display.
3 outras pessoas executaram este guia.
