Ir para o conteúdo principal
C-Clamp Sternum Strap Replacement
  1. C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: passo 1, imagem 1 %32 C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: passo 1, imagem 2 %32
    • Locate the sternum strap that has come off the pack.
    • Replacements for this style of sternum strap are not currently available, so if part or all of the sternum strap is missing, reach out to Patagonia for alternative options.
    Pergunte ao FixBot
  2. C-Clamp Sternum Strap Replacement: passo 2, imagem 1 %32 C-Clamp Sternum Strap Replacement: passo 2, imagem 2 %32 C-Clamp Sternum Strap Replacement: passo 2, imagem 3 %32
    • The 'c-clamp' piece of the sternum strap fits over a plastic tube or ‘rail’ that is inside the backpack strap. At the bottom of this rail there is a fabric flap.
    • Pull back the fabric flap to expose where the rail ends. This is where the c-clamp was designed to be slid on and off.
    Pergunte ao FixBot
    • At the exposed area at the base of the rail, slide the c-clamp back onto the rail.
    • Pull tightly on the fabric flap to expose the area.
    • Maneuver as if parallel parking a car. Start at an angle, slide partially onto the rail, and then straighten out.
    • This can be difficult to do, don’t be shy using some muscle!
    • Repeat the steps above on the other backpack strap.
    Pergunte ao FixBot
  3. C-Clamp Sternum Strap Replacement: passo 4, imagem 1 %32 C-Clamp Sternum Strap Replacement: passo 4, imagem 2 %32
    • Slide the sternum strap to your desired position.
    • Hit the trails with your newly attached sternum strap!
    Pergunte ao FixBot
Linha de Chegada
Uma outra pessoa concluiu este guia.
Zach Mueller
Membro desde: 02/23/23
1.762 Reputação
Autoria de 9 guias
Equipe
Patagonia Membro de Patagonia
Community
9 Membros
Autoria de 153 guias
2Comentários do guia
This is helpful, except where do I find the replacement part! I contacted Patagonia and they no longer make it; they said to try a local sporting goods store or to send to Patagonia and they'll sew on a new daisy-chain version. My local REI does not have these parts either. Bummer!
Jornywar - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 39
Últimos 30 dias: 195
Ao todo: 4,374
