Ir para o conteúdo principal
Bush Pump Riser Main Slider Replacement
O que você precisa
  1. Bush Pump Riser Main Slider Replacement, Head and Handle: passo 1, imagem 1 %32 Bush Pump Riser Main Slider Replacement, Head and Handle: passo 1, imagem 2 %32
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Riser Main Slider Replacement: passo 2, imagem 1 %32 Bush Pump Riser Main Slider Replacement: passo 2, imagem 2 %32
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Riser Main Slider Replacement: passo 3, imagem 1 %32 Bush Pump Riser Main Slider Replacement: passo 3, imagem 2 %32
    • Pull the two lever arms away from the slider.
  4. Bush Pump Riser Main Slider Replacement: passo 4, imagem 1 %32 Bush Pump Riser Main Slider Replacement: passo 4, imagem 2 %32
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Riser Main Slider Replacement: passo 5, imagem 1 %32 Bush Pump Riser Main Slider Replacement: passo 5, imagem 2 %32 Bush Pump Riser Main Slider Replacement: passo 5, imagem 3 %32
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Riser Main Slider Replacement: passo 6, imagem 1 %32
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Bush Pump Riser Main Slider Replacement, Riser Main Slider: passo 7, imagem 1 %32 Bush Pump Riser Main Slider Replacement, Riser Main Slider: passo 7, imagem 2 %32
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Bush Pump Riser Main Slider Replacement: passo 8, imagem 1 %32 Bush Pump Riser Main Slider Replacement: passo 8, imagem 2 %32 Bush Pump Riser Main Slider Replacement: passo 8, imagem 3 %32
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Bush Pump Riser Main Slider Replacement: passo 9, imagem 1 %32 Bush Pump Riser Main Slider Replacement: passo 9, imagem 2 %32 Bush Pump Riser Main Slider Replacement: passo 9, imagem 3 %32
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Bush Pump Riser Main Slider Replacement: passo 10, imagem 1 %32 Bush Pump Riser Main Slider Replacement: passo 10, imagem 2 %32 Bush Pump Riser Main Slider Replacement: passo 10, imagem 3 %32
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Bush Pump Riser Main Slider Replacement: passo 11, imagem 1 %32 Bush Pump Riser Main Slider Replacement: passo 11, imagem 2 %32
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
Conclusão
Jake Devincenzi
Membro desde: 04/18/11
119.040 Reputação
Autoria de 57 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 54
Ao todo: 322
