Ir para o conteúdo principal
Bush Pump Head and Handle Replacement
  1. Bush Pump Head and Handle Replacement, Head and Handle: passo 1, imagem 1 %32 Bush Pump Head and Handle Replacement, Head and Handle: passo 1, imagem 2 %32
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Head and Handle Replacement: passo 2, imagem 1 %32 Bush Pump Head and Handle Replacement: passo 2, imagem 2 %32
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Head and Handle Replacement: passo 3, imagem 1 %32 Bush Pump Head and Handle Replacement: passo 3, imagem 2 %32
    • Pull the two lever arms away from the slider.
  4. Bush Pump Head and Handle Replacement: passo 4, imagem 1 %32 Bush Pump Head and Handle Replacement: passo 4, imagem 2 %32
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Head and Handle Replacement: passo 5, imagem 1 %32 Bush Pump Head and Handle Replacement: passo 5, imagem 2 %32 Bush Pump Head and Handle Replacement: passo 5, imagem 3 %32
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Head and Handle Replacement: passo 6, imagem 1 %32
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
Conclusão
Jake Devincenzi
Membro desde: 04/18/11
117.271 Reputação
Autoria de 57 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 163
