Ir para o conteúdo principal
Building a Caramel Apple
O que você precisa
  1. Building a Caramel Apple, Building a Caramel Apple: passo 1, imagem 1 %32 Building a Caramel Apple, Building a Caramel Apple: passo 1, imagem 2 %32 Building a Caramel Apple, Building a Caramel Apple: passo 1, imagem 3 %32
    • Acquire apple, stick, plate, and wax paper
    • Write your name on small plate.
  2. Building a Caramel Apple: passo 2, imagem 1 %32 Building a Caramel Apple: passo 2, imagem 2 %32
    • Insert the stick into the apple near the stem.
  3. Building a Caramel Apple: passo 3, imagem 1 %32 Building a Caramel Apple: passo 3, imagem 2 %32 Building a Caramel Apple: passo 3, imagem 3 %32
    • Dunk the apple in the hot caramel, making sure to coat the whole apple.
    • Remove the apple from the caramel, twisting it in the air, allowing the caramel to cool slightly.
  4. Building a Caramel Apple: passo 4, imagem 1 %32
    • Place the slightly cooled caramel apple on the waxed paper with the stick pointed up.
  5. Building a Caramel Apple: passo 5, imagem 1 %32 Building a Caramel Apple: passo 5, imagem 2 %32
    • Put a ton of toppings on the caramel apple, starting with the dry toppings, then the wet.
  6. Building a Caramel Apple: passo 6, imagem 1 %32 Building a Caramel Apple: passo 6, imagem 2 %32
    • Put the caramel apple in the refrigerator for at least an hour, or leave it out to cool.
  7. Building a Caramel Apple: passo 7, imagem 1 %32 Building a Caramel Apple: passo 7, imagem 2 %32
    • Once the caramel apple has cooled properly, eat it.
    • Use a knife and fork if you must.
Conclusão
If you find yourself feeling ill after eating this delicious item, you know you've made it right.
Brett Hartt
Membro desde: 04/12/10
127.929 Reputação
Autoria de 143 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.259 guias
3 comentários
Why the !&&* is this on iFixit?
Jake Dupre - Responder
Why not? It's a fun and seasonal.
Tim Asp -
I quite love Carmel Apples, SOOOO... I love this guide!
Ben Capehart - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 670
